97 sierra shudder
Old Jan 6, 2008 | 11:59 AM
tboz89's Avatar
Default 97 sierra shudder
I recently replaced rod bearings and crank in my 350 vortec and i got the engine back in and it runs like a champ but at low rpms goin down the road between 45 and 60 every once in a while there is a shudder when my foot is very lightly in the gas pedal
Old Jan 7, 2008 | 06:05 AM
Argon's Avatar
Default RE: 97 sierra shudder
hmm..not sure...does it feel like a torque converter shudder?
Old Jan 7, 2008 | 10:16 PM
tboz89's Avatar
im not quite sure it does fine in higher rpm range it happensgoing down the highway at cruising speed about1500 rpms butcity driving it is perfect no troubles
Old Jan 8, 2008 | 04:44 AM
Argon's Avatar
its not a miss?..its a rapid shutter?
Old Jan 8, 2008 | 04:31 PM
tboz89's Avatar
im not certain i hooked it up th the diagnostics and it said my cam sensor on the back of the distributor was bad could that be the problem? when i got it all put back together i had a little trouble getting the distributor back in time and i got it to where it would run smoothe and it didnt do it until a couple days into driving it i know everythings not perfect by any stretch of the means im an 18 year old kid
Old Jan 9, 2008 | 12:53 AM
stopspazinout's Avatar
have you checked the timing or the cam sensor?
Old Jan 10, 2008 | 08:00 PM
craig91chev's Avatar
I had something similar on my truck it was a high frequency shudder, same scenario. A month or so later my drive shaft hanger bearing blew. Unless your sure its something in the engine, I'd get it up on stands and check the drive shaft.
balls79
Apr 3, 2009 03:24 PM
blue_sniper_fox
Feb 13, 2009 01:57 PM
lowrider_62
Mar 23, 2008 11:39 AM
NutHouse101
Oct 10, 2007 04:51 AM
