Bigger tires and gas mileage
Old Jul 9, 2007 | 07:32 AM
superddd's Avatar
Default Bigger tires and gas mileage
I've read about you guys putting bigger rubber on the rims and losin milage on the 5.3's and what not, but that is with the 3.73 dif. I was wondering if my milage would drop much if I boosted mine - I've got the 6.0 with 4.10 dif and it only has 245's on the rims. The tires look tiny for the truck and I was thinking of stepping it up a little - not huge but to at least fill the wheel well like it's supposed to be. Should I see the same drop in milage wor with the different setup will it stay the same?
Old Jul 9, 2007 | 08:06 AM
hunt4game29's Avatar
Default RE: Bigger tires and gas mileage
Well with my trip to michagin i finally found what my mileage was after i got my big tires but with my exhaust, tb spacer and k&n filter my mileage was the same as before.
Old Jul 9, 2007 | 04:46 PM
smoke20's Avatar
superdd - what are all the dimensions on your tires? If they are less than 33" and you increase to 33" you will be in your best rpm range with 4.10 for milage. I have the 3.42 and it dropped a little with 33" tires over the stock 31.7 in tires. I wish I had 4.10.
Old Jul 9, 2007 | 06:22 PM
So that meens you need 285 75 r16 tires.
Old Jul 9, 2007 | 09:43 PM
78chev2bnice's Avatar
Member
what is the common gas milage range with a 6.0L? somewhere between 9-12?
Old Jul 10, 2007 | 10:41 PM
superddd's Avatar
When I first got the truck it was anywhere between 11-13 c/h but I've put on a tbs and it actually boosted up to 15 highway. As I said earlier - thats with the 6.0 on 4.10 rearend with 245's on the tires. Sounds like I need to size up my tires a bit! Thanks guys.
moose
Silverado/Sierra FAQs
16
Jan 6, 2023 02:42 PM
AKSFM
Apr 13, 2010 03:54 AM
moose
Mar 4, 2008 06:35 AM
bryan08252
Aug 21, 2007 03:27 PM
bigred29067
Mar 14, 2006 02:20 AM
