blown tranny!
Old Jan 14, 2007 | 07:38 PM
00_slammmed's Avatar
Default blown tranny!
Ihave a 2000 silveradoext cab 5.3L i blew my trannyto peices i lost 4th then 3rd and now 2nd is slipping this all happend within a few minitues by the way fluid is silver so now its time to do bigger and better right!so im looking for a good performance tranny because i am a little hard on my truck any info on what brandand where to get it from would be great!
Old Jan 14, 2007 | 08:03 PM
Ballzac's Avatar
Default RE: blown tranny!
i would suggest ats transmission its what all the diesel us around here to pull with. they make stages 1 to 5 then they make the extreme. they have a life time garentee.
Old Jan 14, 2007 | 09:23 PM
i only see trannys on there for diesel
Old Jan 14, 2007 | 10:04 PM
Ballzac's Avatar
they only make full tranny for diesel but they should have a rebuild kit i no they make some bad cluch packs or allison. im sorry they might not make anything for gas but they do have some bad tranny thought
Old Jan 14, 2007 | 10:09 PM
Ballzac's Avatar
hey i found it they make one but u have to call them ok here is the site address it was under hummer but it is the same tranny that is in your truck.
http://www.atsdiesel.com/ATSWebsite/...sGM/Hummer.asp
Old Jan 15, 2007 | 10:08 PM
chevy1224's Avatar
try jegs.com they make some nice trannys on there or actually sell them but yea thats a good place to get them. Good luck
Old Jan 16, 2007 | 02:34 AM
makoltd's Avatar
A replacment Tranny from GM, not a ReMan will cost you $2700 installed. They put an 04 in mine just 7 mths ago. The tranny went because of the SUN Gear. It is aknown weak point in all the Silverado Trannys. I can say this with certainity. If you have an AAMCO around you, give them a call and they will tell you all bout it. If your an owner who hasn't had the tranny go, it costs about $800 to get it fixed outside of a GM dlrship.
GL
Greek
Old Jan 16, 2007 | 09:14 PM
chevy1224's Avatar
I would get a higher performance one if you were gana spend that much. Then you could put it in yourself for way cheap. Not that big of a deal if you have somewhere to do it. http://www.jegs.com/webapp/wcs/store...10559_-1_10557Try that one.
Old Jan 17, 2007 | 07:53 PM
thanx for the info buti found a place close by that sells high perf trannys http://www.maddog-transmissions.com/i just bought a punisher 4L65E from him with a 2200 stall(look underhis punisher 4L60E from the product menu) i just finished putting it in today and this tranny is sweet
Worf
Dodge/ Ram How-To's and Tutorials
Jul 10, 2012 05:03 AM
Worf
Ford How-To's and Tutorials
Apr 14, 2010 04:06 AM
DrewJ
Feb 10, 2010 12:27 PM
4WheelRunner
Nov 11, 2008 11:42 PM
j_remington
Aug 4, 2008 03:55 PM
