Brake light
Old Jan 23, 2010 | 09:08 PM
redneckchevy's Avatar
Default Brake light
Hi everyone new to your forum with a problem, just bought a 1990 1500 Chevy truck and the brake light has always been on the brakes work perfect abs OK the e brake switch looks like its actuating but today the light started blinking. It blinks ten times then goes off then blinks ten times again has anyone else seen this. Kevin
Old Jan 24, 2010 | 05:08 AM
RUFFNECK4LYFE's Avatar
Did ya check fluid level??
Old Jan 24, 2010 | 01:38 PM
Yes I checked the fluid
Old Jan 24, 2010 | 03:27 PM
Lets see, go down the road where there is no traffic and get up to speed about 35 mph and slam hard on the brakes. Just test it to see if it has good pressure or if it goes to the floor when this is done.
Old Jan 24, 2010 | 10:16 PM
Good pedel stops stright no lock up everything works as its suppose to except the light. Kevin
Old Jan 25, 2010 | 05:21 AM
Hmmm the only thing I can think of is the switch for the E brake is stuck.
Old Jan 25, 2010 | 09:55 AM
tasutt2009's Avatar
If the blinking light seems to be syncronus than I would think your truck is telling you to check for code(s).
Old Jan 25, 2010 | 07:41 PM
Thats a good point, I would look into that. Might call the dealer and ask a parts pro if that is possible.
Old Jan 27, 2010 | 09:41 PM
Problem solved it turned out to be the brake light switch on the brake pedal $12 and all is well and working fine
Old Jan 28, 2010 | 04:27 PM
Cool deal!
mic_in_chevy
13
Aug 14, 2014 06:45 PM
05chevytruckguy
Feb 15, 2012 09:58 PM
Mule man
Mar 29, 2009 10:23 PM
munter
Oct 13, 2008 05:54 AM
dharsen
Jan 25, 2008 12:54 PM
