brakes
Old Apr 14, 2009 | 07:26 PM
7060's Avatar
Default brakes
I have a 91 K2500 with drum rear brakes, and my left rear drum has a squeal when i am at low speeds without the brake pedal pushed. I just put new shoes on it, but it also did it before with the old shoes. any suggestions? thanks
Old Apr 14, 2009 | 07:46 PM
EvansBlue's Avatar
Its sounds like it out of adjustment.
Old Apr 14, 2009 | 08:07 PM
chrisbmo2000's Avatar
is it a constant squeal or intermitant? a constant sqeal would mean it could be a backing plate that is either bent or out of round and rubbing or the shoes could be mis adjusted
Old Apr 14, 2009 | 08:49 PM
7060's Avatar
I think they are self adjusting arent they? It seems like they got tighter since I adjusted them.
Old Apr 14, 2009 | 08:52 PM
7060's Avatar
And it is a constant squeal. It only does it when you let off the gas at under 10mph
EvansBlue's Avatar
They adjust themselves outward not inward, and can get too tight.
Old Apr 14, 2009 | 09:21 PM
7060's Avatar
Ill try loosening them up a little. thanks for the help
Old Apr 16, 2009 | 11:37 PM
dmccartyfan's Avatar
Any luck on finding the squeal?
Old Apr 17, 2009 | 09:13 PM
7060's Avatar
Well I loosened the adjuster and it worked fine for a day, but then it started back again but not as bad. It still does it when you let off the gas and you can feel it wanting to stop you. Maybe oil on the shoes? I jacked one wheel up and it turns fine but you can hear the shoes rubbing barely.
Old Apr 18, 2009 | 12:20 AM
After driving a bit, the adjuster self-adjusts the shoes outward. I think it's 'normal' for them to drag slightly. Did you change the hardware along with the shoes (springs, clips, etc.)?
