A/C problems
Old Mar 2, 2016 | 01:15 PM
Greybomber's Avatar
Default A/C problems
Hi my name is Andre and I own a 1992 Chevrolet c1500 with a 305 engine. So about a year ago I had gotten my a/c fixed and converted from r-12 to r-134 system and everything was working fine until my alternator went out so I replaced my battery and alternator and now my a/c will not blow cold the compressor doesn't engage the fuses and relay are good freon is good no leaks what would be the next step on something to check? The alternator I installed is a 105 a alternator if that matters thank you verymuch !
Old Mar 2, 2016 | 05:31 PM
Hmmm. I thought that my 1992 had a 130a but I could be wrong. I had a 350 though.
SOmeone with better information should chime in shortly
Old Mar 2, 2016 | 08:02 PM
Greybomber's Avatar
I'm pretty sure the same parts would go on the 305 as well.
Old Mar 8, 2016 | 08:48 PM
GMC_Chris's Avatar
My 93 G20 with the 350 is 134a. There is a jump you have to do with a wire when you charge my system. I can't do it and have a local guy who does, but somebody here knows how to do it I'm sure. I had plenty of refrigerant and no cool air, the guy pulled his trick with a wire, cool air.
Old Mar 9, 2016 | 10:29 AM
Greybomber's Avatar
I'll look it up and and see if I can do it thanks for the info I'll post back what I find
Old Mar 9, 2016 | 11:57 PM
Greybomber's Avatar
So my compressor clutch works when I jump it from the battery but it still doesn't blow cold air this weekend I'm going to get it filled with frion and see if that helps any
Old Mar 11, 2016 | 08:25 PM
NullHead's Avatar
Yeah, if it still doesn't blow cold, you'll need to touch the pipes going into the heater case to make sure one of them is cold. If the pipes going into the evaporator aren't cold, then there is indeed no refrigerant in the system.
Time to get a gauge set
Old Mar 14, 2016 | 12:51 PM
Greybomber's Avatar
Ok I will do that
