Changing of rotor
Old Jul 6, 2010 | 04:30 PM
bpa1216's Avatar
Default Changing of rotor
98 gmc sierra 2wd 5.7. How hard is it to change out the rotors.
Old Jul 6, 2010 | 05:37 PM
Not hard at all...
Remove wheel
Remove Caliper (2 - Allen Bolts)
Remove Center Cover (use flat head or flat punch)
Remove Cotter Pin and Large Nut
Pull it off (there will be a bearing in the front and rear and a seal in the rear only)
Good Luck!
Old Jul 6, 2010 | 07:17 PM
timber74wolf's Avatar
Then reinstal in reverse order, but you will have to repack the bearing with greese and get the torque specs to torque the wheel bearing.
underoathpac
Aug 10, 2007 04:53 PM
vintagecar
Nov 5, 2006 06:37 PM
lossinthought
Sep 24, 2006 06:18 PM
daggettdaddy
Sep 24, 2006 01:13 PM
krwzn1
Mar 26, 2006 10:59 PM
