clunk in steering
Old Apr 5, 2010 | 03:36 PM
welder122803's Avatar
Default clunk in steering
i have an 04 silverado 2500hd. just started feeling a clunk in my steering wheel when i turn left. check ball joints, tierods, and front drive lines for extra play all look good and are in tollerance any suggestions
Old Apr 5, 2010 | 05:52 PM
Probably the infamous steering (intermediate) shaft clunk. Have you serviced it lately. There is a replacement shaft or you can just grease that one every so often. It takes about an hour the first time 30-45 minutes after that. It should do it turning both directions though.
Old Apr 5, 2010 | 06:00 PM
zleehw's Avatar
Default silent recall
The intermidiate shaft is under silent recall by chevrolet.
Take it in and say you have the CLUNK and they should replace it no charge.
Old Apr 6, 2010 | 07:39 PM
machman72's Avatar
Won't the dealer only replace it for free if your truck is under warrenty?
I recently bought an 02 Sierra Z-71 with 125K miles that has a mild case of this issue. I did some research and came up with this place http://www.gmpartsdirect.com/. The part came to $67 shipped.
Hope this helps.
Old Apr 6, 2010 | 09:17 PM
RUFFNECK4LYFE's Avatar
Hope this helps.
Recalls deal with every truck made by GM, warranty is different.
Old Apr 7, 2010 | 08:18 PM
GMC1989's Avatar
The intermediate shaft is not a recall because it is not a safety issue. I have replaced many of these for the same concern. Unless you have an extended warranty on your truck they will not replace it. The part is a little more than 100.00 dollars.
Mr_Shamrock
May 19, 2009 08:26 PM
bad2006z71
Mar 24, 2008 01:35 PM
2000_z71
Aug 12, 2006 11:40 PM
GTRMN101
Jul 21, 2006 04:59 PM
fearless_fb
Jul 16, 2005 12:52 PM
