Common Chevy & GMC Issues
Old Apr 11, 2016 | 09:47 PM
  #141
GMC_Chris's Avatar
Originally Posted by nikl
I just do not like the tiny back door look at all! Liked the old extended cab better.
Old Apr 12, 2016 | 05:33 PM
  #142
Razoo's Avatar
Does anyone know anything about the plastic Ls intake manifolds become porous, and seeping (not leaking) coolant?
Old Apr 20, 2016 | 11:11 AM
  #143
Man In Black's Avatar
Originally Posted by procarry21
2000 chevy silverado- drivers rear caliber freezes (3 diffrent trucks), tow package trucks the rear junction block corrodes, pasenger door lips rust like none other, cab corners are bad too, tail gate cables, drivers side rocker rust out, driving and the lights will suddenly go out and right back on, yolk clunk, gas gauge sending unit is ****
2004 duramax 1 ton single axle heated seats go out, seat motors go out, the grill cover gets brittle and falls apart after a season of snow plowin, filler neck on the tank will crack if your not carefull, two glow plugs
2008 duramax dully, third and fourth door electrical problems, fiberglass hips dont take alot of abuse, two transfer cases, four wheel bearings, one glow plug, front end gets off camber too frequently for me
My 2002 headlights will go out suddenly on high beams . It has a bad dimmer switch that needs changed. Don't know if the aftermarket switches are any good , but the gm switches are more than double the price.
Old Jan 29, 2018 | 09:44 AM
  #144
PaulB573's Avatar
1990 K1500 has a short in the headlights on the passenger side and the horn is stuck on. I can’t figure it out
Old Jan 29, 2018 | 02:32 PM
  #145
BirdDooHead's Avatar
I don't have a repair answer for you, but if the 1990 truck has a horn relay, you could pull it out just to silence the horn long enough for you to work on the truck.
Somehow your post is in the "Common Chevy & GMC Issues" thread.
I think your post will get more views if it was in the main forum section for these trucks & had its own thread. Then the people who know about your truck's problems will be able to see it.
Perhpas you could write a moderator to ask him or her to move your question.
Or-
If you go to this page-
https://www.truckforums.com/forum/ch...erra-forum-11/
and click New Thread, you can post your question where everyone will see it.
Hope This Helps & Good Luck With Your Repair!
Old Jan 31, 2018 | 10:57 PM
  #146
dougo83's Avatar
2006 Silverados with the 4.3L. RUN, don't walk, away from this piece of trash motor. With regular maintenance and light driving, this truck has had more problems than any vehicle I've ever owned.
Old Apr 9, 2018 | 05:50 PM
  #147
ve6bmw's Avatar
Angry Trixee is havin issues
Hello,, Bought a 97 GMC Sierra ext cab shortbox stepside last summer, 5.7, auto Recently I had the "cat" code come up, scanned to find out cat bank 2, was told my cat was bad ( plus all the gas I am smelling ) deleted code and has'nt come back. My prob is this, if the cat is bad will it cause the truck to buck and sputter, stall and sometimes not start?
well,, went out truck started.. went to grocery store no probs...comin home, get one block away and she dies on me in the middle of an intersection and refuses to start,, she cranks but seems there's not enough spark
Old Apr 10, 2018 | 02:52 PM
  #148
67C10SWB's Avatar
Default ABS, Brake, Service 4wd, no blower 2005 Z71
new guy here....
i'm sure this has been addressed. i'm not too versed at navigating this site yet though.
2005 Z71 250K miles. ABS, Brake and service 4wd lights are on and no blower motor AND no cruise.
I've replaced the ignition switch and both front hubs......
can you guys direct me with where to start trouble shooting.
Thank you in advance
Old May 30, 2018 | 08:48 AM
  #149
a2t's Avatar
a2t
GM Trucks auto parts
Lots of improved replacement parts here that you otherwise would spend a paycheck on to buy entire assemblies from GM. Theres also some helpful DIY's within the product pages incase you want to see how to take apart the mirrors or doors.
Just an FYI to help out the forum members
Old May 30, 2018 | 09:17 AM
  #150
ve6bmw's Avatar
UPDATE
Patches is back up and running. After numerous so called mechanics in my area kept steering me towards the spiders being the prob only to turn out to be cap and rotor. Thanks for all the advice here. Now just have to finish off the cats
