Diesel Performance
Old Jul 17, 2005 | 11:13 AM
beinc's Avatar
Default Diesel Performance
I have an '05 GMC with a Duramax. I put a programmer in it and that worked out okay. Then I put a 4" exhaust on it. Then came the problems. I couldn't drive the truck for more than 30 minutes without a trouble code popping up. After doing some research, I found out that the new Duramax, the LLY, has some features that the LB7 doesn't have. The main one being that the turbo has a variable output that, along with the EGR system, requires a reading of the exhausts back pressure to work properly. Back pressure is what I'm trying to get rid of. Does anyone have a solution for this problem? Maybe a way to trick the sensor into thinking there is back pressure?
In2Trux
Dec 3, 2013 08:41 PM
1994GMCSierraZ71
11
Mar 15, 2012 08:11 PM
bad2006z71
10
Aug 10, 2011 08:21 PM
Jack Bauer
Oct 13, 2008 03:52 PM
propaneman
Oct 29, 2007 10:07 PM
