Differential Leaking After Gear Oil Change
Old Oct 13, 2012 | 01:55 AM
p95dx's Avatar
Default Differential Leaking After Gear Oil Change
I just recently changed the fluid in the rear differential of my truck and unfortunately the next day I noticed it was leaking. It appears as if it is leaking from the seal because the housing is dry. I changed the fluid using Mobil 1 75w 90 gear oil and I replaced the gasket and used black rtv sealant. Anybody have any ideas? My truck is a 2001 Silverado 1500 LS 5.3L 2wd. It has the GT4 differential. It asked for 2 1/4 quarts and I may have put in slightly more than that, but not by much. It was still under the fill hole and the additional amount wasn't much.
Thanks in advance for the help!
Old Oct 13, 2012 | 09:18 AM
xpeder's Avatar
pinion seal leaking probelm wore out or a groove wear in the york where the seal ride
Old Oct 13, 2012 | 11:08 AM
p95dx's Avatar
I should add that it was not leaking before I changed the oil.
p95dx
12
Apr 23, 2012 10:57 AM
johnnstace
Aug 21, 2011 11:57 AM
09GMCSierra
May 8, 2011 12:44 PM
SmallFeesh
10
Aug 11, 2010 06:49 AM
ArmyAviator
Sep 27, 2008 03:42 PM
