door pins and bushings
Old Mar 20, 2008 | 05:16 PM
daveofhiram's Avatar
Default door pins and bushings
hi guys, could someone post a link on pin and bushing replacement(door), i've never repaired the hinges without bolts.....
Old Mar 21, 2008 | 11:59 AM
gpet6669's Avatar
Default RE: door pins and bushings
You need to get replacement pins and bushings (usually you can get them from a local parts store). Then all you need to do is remove the old pins (with the door being supported by something else.) and bushings. Drive in the new bushings and pins. A piece of advice, try not to remove the door spring. Also do on pin at a time. With a little persuation and swearing, it will get done. Good luck. Also what year and model truck do you have?? That will help us determin exactly what to tell you.
Old Mar 21, 2008 | 02:30 PM
Argon's Avatar
i have no idea of your tools/knowledge,but thats not an easy job
SweeperForce
Aug 8, 2012 09:38 AM
offroadz71
Mar 28, 2012 02:46 PM
GMCanuck
Jan 13, 2011 09:45 PM
iana
Oct 16, 2010 12:19 AM
Chevycowboy
Apr 18, 2008 08:39 PM
