edelbrock headers
Old Nov 17, 2007 | 02:10 AM
ito707's Avatar
Default edelbrock headers
So I been thinkin about purchasing some edelbrock shorty headers but can't really decide between the ceramic and the ti-tech coating.The ti-tech is supposed 2 withstand higher tempatures.Ceramic costs more and has a polished finish.Has anybody ever tried or know someone who's tried the ti-tech coated?Any help would be appreciated.
Old Nov 17, 2007 | 08:26 AM
smoke20's Avatar
Default RE: edelbrock headers
I have not tried the ti-tech, but I was told by several sources that the ceramic will resist corrosion the best. And I live at the coast so that is important to me. The performance should be the same though.
Old Nov 17, 2007 | 11:26 PM
popo's Avatar
I wrapped my headers with the thermo tec wraps and i noiticed a slight difference in power after they dried and really got a good seal. they shield the heat away from the engine and heat up the exhaust gas? anyway they are for creating better scavenging for the exhaust. they seemed to work really well and only cost about 40 bucks for my shorties. (on my mustang R.I.P.)
Old Nov 17, 2007 | 11:27 PM
popo's Avatar
sorry i forgot the point of my response. I would go ceramic and then wrap em. it would be pointless to cover up the polished ones.
Old Nov 18, 2007 | 05:49 PM
Cracker's Avatar
I advise agaist wrapping aftermarket headers without checking with the manufacturer. Headman will not honor the warranty if you wrap them. This may be true for other brands. My friend learned the hard way after blowing a hole in a set.
Old Nov 19, 2007 | 05:57 PM
smoke20's Avatar
Edlebrock will not warantee either.
Old Nov 19, 2007 | 08:24 PM
ito707's Avatar
I got the new ti-tech coated headers today.Am I goin 2 need aftermarket high temp plug wires or should I leave the stock Ac Delcos.Also does anybody have any tips or suggestions on installing headers.thanx
Old Nov 19, 2007 | 08:33 PM
Cracker's Avatar
If they are "direct replacement", go bolt by bolt. Different wires should not be necessary. Just make sure none touch the headers after install.
Old Nov 19, 2007 | 08:41 PM
smoke20's Avatar
If you look back at the post titled "christmas presant", you will see pics and notes from the install of mine. Easy to do, just take your time, and make sure to have a 45 degreee socket for getting the exhaustpipes loose as the top bolts are a tight fit.
Old Nov 20, 2007 | 12:14 AM
ito707's Avatar
They are direct fits.Why shouldn't none of the wires touch the headers after installation just wonderin??
