engine light
Old Feb 15, 2011 | 01:16 PM
mick's Avatar
Default engine light
Hello everyone..great sight....I have a 2004 chev silverado 2500 HD, I have had it for 6 months..the check engine light came on in the first month and it was the knock sensor..I replaced both of them even though only one was at fault...after a month the light is back on..I used my code reader and it said knock sensor..I thought that mabe that this was being caused by cheap gas so I started using premium gas and the light went off..after another month it is back on reading knock sensor..I am wondering if there is something else I can try to fix this other than replacing the sensors again...Mick
Old Feb 15, 2011 | 05:45 PM
chevychase's Avatar
Are you hearing any detonation/pinging ? Especially up steep inclines.
What code number are you getting on knock sensor?
Old Feb 15, 2011 | 07:07 PM
skoot61's Avatar
Member
Yeah Mick, I changed the same sensors out in my 03 1500HD. The engine service light came back on a short time after my replacement too .... I'm so frustrated from trying to correct this problem without success after spending a lot of money for nothing I've just put a small piece black electrical tape over the icon light. I don't feel so bad if I don't see it on glowing at me. Come back and post your results if you continue to troubleshoot the Engine Service Light situation.
Best of Luck, Skoot61
Old Feb 15, 2011 | 07:12 PM
mick's Avatar
Not hearing any pinging the truck seems fine..the code reads as follows..
PO332
knock sensor 2
circuit low
input (bank2)
I have already replaced this sensor ..I am wondering if there is something else going on to cause this
Old Feb 21, 2011 | 06:04 PM
mick's Avatar
After filling it with premium gas and using all but 1/4 of a tank the egine light went off..Although when I put my scanner on it still reads the following..PO332 KNOCK SENSR 2..but the irritating light is gone for now..
Mick
Old Feb 21, 2011 | 09:41 PM
RUFFNECK4LYFE's Avatar
Did you also replace the knock sensor wire harness? It is recommended while doing this. I also did this on my truck and have not had a problem since.
Old Feb 22, 2011 | 07:17 AM
honestblades's Avatar
Member
Although it is unlikely, it is possible that the new sensor is faulty. Anytime something is mass produced (auto parts) you can expect a bad egg here and there. Turn the key over once like you would do to turn on the radio, and stomp on the gas pedal 3 times very quickly. See if that makes the dummy light go away.
Old Feb 22, 2011 | 06:58 PM
chevychase's Avatar
Did you clear codes. If not will read old codes.
Old Feb 24, 2011 | 02:28 PM
mick's Avatar
Yes after I cleared the codes The light is off after I swicthed fuel..Better Quality gas ??
mic_in_chevy
13
Aug 14, 2014 06:45 PM
08limited2148
Apr 13, 2010 04:07 AM
Mule man
Mar 29, 2009 10:23 PM
munter
Oct 13, 2008 05:54 AM
dharsen
Jan 25, 2008 12:54 PM
