Fan Clutch Torque
Old Sep 8, 2010 | 04:10 PM
Default Fan Clutch Torque
I have noticed my A/C was getting warmer at idle and my temp was creeping up a little. I diagnosed my fan clutch as the culprit and bought a new one. I installed it today and used a big adjustable wrench and a hammer to get it off (it is a 5.3 with the screw on fan clutch) and I used the same technique to tighten it. The instructions that came with the fan gave a torque spec for installation. How would you torque this? Also how have you guys installed yours? From what I can see - the way the motor spins helps to keep it tight, but it gives a warning in the instructions that if the fan is not torqued properly it can spin free when shutting the motor off. Any suggestions?
Old Sep 9, 2010 | 12:19 AM
RUFFNECK4LYFE's Avatar
I always just put lock tite and tightened by hand. Its just a precaution when the motor stops turning the nut has a chance of breaking loose. But just a little of the red stuff was good enough.
theonn
Jul 18, 2009 12:07 AM
tailtap
Oct 18, 2008 03:48 AM
Prescott
Sep 3, 2007 03:15 PM
jcbst12
Sep 1, 2007 09:36 AM
wade
May 5, 2007 10:21 PM
