fuel gauge question
As far as the popular culprit I think the sender acts up more than the gauge, however it is not set in stone and could be the gauge as well. As far as how I would go about checking it - I would unbolt the bed (easier than it sounds) and pull the pump and sender out to see if it is stuck. Unless you have access to a similar truck that you can swap entire clusters to see if that helps. The cluster swap is definitely easier, but from my experience the sender is usually the issue.
waytooevil
Oct 28, 2007 10:48 AM
