Fuel PUmp?
Old Apr 9, 2008 | 10:54 PM
  #11
bondv007's Avatar
Default RE: Fuel PUmp?
So how do i clean the MAF. Any special fluids that i have to use or should i just blow on it or what? Please help?
Old Apr 10, 2008 | 09:14 AM
  #12
rxsteven's Avatar
MAF cleaner or throttle body cleaner.
Old Apr 10, 2008 | 10:21 AM
  #13
jcbst12's Avatar
Pull it off, spray it with TB or MAF cleaner like rxsteven said. Then let it sit for a minute to dry. Spray it agin if its still dirty. The tiny "pill shaped" sensors between the metal bars need to be silver and free of heavy dirt and debris. Then pit it all back together. Bada Boom you done. Do you TB real good too. Open the butterfly and spray it all out, wipe it with a rag, etc.
Old Apr 18, 2008 | 06:26 PM
  #14
bondv007's Avatar
Ok i cleaned the maf but still no luck. I also check the fuses for the fuel pump and they are ok. so should i assume its the fuel pump? Im also going to change the fuel filter today and see if that helps.
Old Apr 26, 2008 | 08:09 AM
  #15
topknotch06's Avatar
yah... way easier to take the bed off... and make sure u seat the rubber seal correctly.. otherwise you'll lose a good amount of pressure... good luck
Old Apr 30, 2008 | 12:00 PM
  #16
bondv007's Avatar
Alright guys check it out, it turns out my fuel pump is fine it looks like i had a bad MAF sensor. I tried cleaning it but i ended up buying a jet performance one instead. I also bought the K&N CAI but now it looks like im misfiring on one of the cylinders. the truck runs now and stays on but im losing power. I checked all the plugs but could it be the spark plug wires. I tried checking the wires in the dark to see if i could see anyspark and i did see a little from where the wires connect to the coils but is this normal? I am also getting a check engine light that blinks only when i step on the gas. If i am just idling it just stays lit. I thought my truck was goign to be ready to haul *** but now this. WTF? Please help!!!!
Old Apr 30, 2008 | 12:12 PM
  #17
jcbst12's Avatar
No, there should be no visible spark at all! Is it the wire or the coil? Propbably need new wires. Try that first. Then if it still messes up I would remove the MAF sensor and get a factory one. The aftermarket ones can screw with the engine AFR and Fuel Trims.
In2Trux
Apr 19, 2015 08:50 PM
ecarri100
Jan 9, 2011 09:54 AM
chrisbmo2000
Dec 24, 2010 03:35 PM
needshave
Jan 24, 2010 12:53 PM
jrk99
Dec 7, 2009 11:57 PM
