GMC 2500HD rear end grinding, need help!
Old Apr 28, 2011 | 04:35 PM
LtDan's Avatar
Default GMC 2500HD rear end grinding, need help!
I've got an '01 GMC 2500HD 6.0, auto with I think a 10.5" 14 bolt rear end, 4.10 gears, w/ 140K. Just got back from a long trip pulling a 24' trailer with camper in the bed, the last couple of hundred miles I noticed a roaring or grinding noise coming from the rear end. Opened it up, I have a little experience with rear ends but not much, replaced the small brg on the pinion shaft as it seemed a little sloppy, the other brgs. on the pinion seemed fine and the chunk spun freely with little noise with the axles out. Put in fresh oil and still have the same noise, btw it is a limited slip.
Anyone got any ideas as to where I go next, thanks for any help you may have.
Dan
Old May 6, 2011 | 02:33 AM
jvp's Avatar
jvp
Member
Have you checked the wheel bearings?
At 140 they may be giving it up?
jvp
furious82st185
Jan 17, 2011 08:54 AM
paparoach
Jun 25, 2009 08:21 PM
Drifter59
May 15, 2009 01:11 AM
sqdqo
Mar 21, 2009 06:42 PM
nathan89
Sep 22, 2008 07:48 AM
