grease inside rear driver side wheel
Old Jan 7, 2012 | 11:40 PM
iward05's Avatar
Default grease inside rear driver side wheel
I have had this problem for quite a while now. A year maybe? Unfortunately I havent had any extra money to maintain my truck like it should be...Anyway, on the inside of the rear driver side wheel there is a buildup of thick black grease. It also appears to be coating the caliper as well as other parts around the wheel and brake. I thought maybe the differential might be leaking or something, but I looked and there is little to no evidence of leakage on the differential itself. I know this is not just a grime buildup from the road, because this is the only wheel that it is on. Any ideas what this could be?
Old Jan 8, 2012 | 12:18 AM
NullHead's Avatar
Well, really the only grease on the rear wheels, are the differential fluid that's inside the diff its self. Check your differential fluid level, and add fluid if necessary.
It's likely that you need an axle seal.
jte52003
Feb 6, 2012 06:42 PM
sethj
Aug 4, 2008 04:12 PM
hunt4game29
14
Jul 9, 2007 04:42 PM
hotrod04
Jun 11, 2005 09:15 PM
