header bolts backin out
Old Jul 23, 2008 | 09:47 PM
Rhyse62's Avatar
Member
Default header bolts backin out
its really starting to **** me off, seems like once a month i gotta tighten them. any idea, they came with locking washers but it dont seem to do much
Old Jul 24, 2008 | 11:08 AM
timber74wolf's Avatar
Default RE: header bolts backin out
What brand headers? And did it come with the bolts and locking washers? You could upgrade to a better set of heder bolts.. or lock-tite....?????
Old Jul 24, 2008 | 06:06 PM
rxsteven's Avatar
Only use look tight if you are selling the truck to someone you hate! Is the thread inside the head ok?
Old Jul 24, 2008 | 08:44 PM
Rhyse62's Avatar
Member
the threads are solid it had the stock manifolds on that had never been taken off and i replaced it with edlebrock headers. i dont like the lock tite idea because i think the heat would break it down
Old Jul 24, 2008 | 11:11 PM
rxsteven's Avatar
You could try Fastenall I think they can get you some squash washers But im not sure if they make them that small or if thats the wright name for them. What they are is two washers with bump things that lock when you torque them down. Ill see if I can find a picture of some for you.
Old Jul 25, 2008 | 06:53 PM
I was just remembering when I took my stock manifolds off my 1990 the threads were solid too... well it seemed like it. You might want to run a tap in the head to retrace the threads like me and my buddy did and fixed the problem.
Old Jul 28, 2008 | 10:04 AM
gpet6669's Avatar
Use the lock tight and only use what you can get back out, also in the past I have seen guys use two gaskets on each side to help with the heat-up and cool-down cycles to allow the headers to have some room to heat up and cool down with out loosening the bolts. If you really want to fix the problem then get the new headers with the extra thick flanges and then use two gaskets and the lock tight. Good luck.
mechanical73
Automotive Parts Wanted
Nov 24, 2007 08:37 AM
mechanical73
Nov 21, 2007 06:42 PM
nextlevel
Aug 12, 2007 07:51 PM
Dyeguy
Jan 7, 2007 11:29 PM
