Headlight bulb replacement
Unfortunately, the light has to be removed from the truck. There are 2 screws on the top, and two more from the underside- GM's procedure involves removing the tire and fenderwell cover to access. Then there are tabs along the bottom side of the headlight assembl. What a P.I.T.A.
I went ahead and added HID kits into both my low and high beams. The low neams, I could reach the bulbs, but definately not with the high beams- that is when I had to remove them. I sought the procedures from my buddy at the GM dealership. They have it on their system as a 1.5 hour labor rate to change a bulb.
I think the 2 tab, twist and pull system for the headlight removal changed in 2007. My Sierra is an 08, and needs to have the entire light removed as stated above.
http://www.retro-solutions.com/
is where I purchased my HID kits. I did the low beams, the high beams, the 5202 low beams and a 55 watt kit in my PIAA off road lights on my pushbar.
Im actually going to remove the PIAAs and plan to replace them with LED lights from:
http://www.rigidindustries.com/Off-R...ights-s/89.htm
is where I purchased my HID kits. I did the low beams, the high beams, the 5202 low beams and a 50 watt kit in my PIAA off road lights on my pushbar.
I have the high, lows and fog all in 35 watt kits 6K and the PIAA's in a 55 watt kit 6k also.
Anyone interrested in the PIAA's with the HID kit installed- $250 plus shipping from NJ
I spent $300 for the lights and another $200 for the HID kit. They are PIAA 520 SMR Chrome with this HID kit http://www.retrosolutionsllc.com/ser...VERSION/Detail. They have been barely used since I live in the city and don't get off roading much/at all. I bought them for the look for the bull bar
I also have 1 spare H3 HID capsule included too
http://www.aztekfanclub.com/SMF/inde...ach=2088;image
http://www.aztekfanclub.com/SMF/inde...ach=2132;image
http://www.aztekfanclub.com/SMF/inde...ach=2134;image
Piper316
Aug 8, 2011 02:26 AM
majordad
Nov 23, 2007 06:59 AM
TSMITH1499
Aug 29, 2007 08:07 PM
