Headlights
Old Oct 26, 2008 | 01:21 PM
98Silverado4Ever's Avatar
Default Headlights
I have a 98 Silverado and when I turn on my headlights at night they turn off. The lights are on when the switch is turned off and when I turn the marker lights on. I can switch to my high beams when the lights are turned on but not my low beams. Anyone know how to fix this problem??
Old Oct 27, 2008 | 07:20 AM
HarderThanRocks's Avatar
Default RE: Headlights
pull the switch apart maybe? Thats what I had to do on my wifes car and it fixed it...
Old Oct 27, 2008 | 01:09 PM
gpet6669's Avatar
So your day time running lights are working but your regulare lights aren't? I would have to say it is either the switch or fuses or even possibly the relay (If it has one for the headlights, I am not positive that it does have one). I would check a repair manual and see what it says to do about the problem. I have never heard of this before. At least you can drive with the daytime running lights! Good luck with the problem.
Old Oct 28, 2008 | 08:50 AM
Yea I guess I should have clarified that earlier. Yes, my daytime running lights do work. I also found out sometimes after a little bit of driving I am able to turn on my regular headlights, but I dont dare try switching from high to low beams again.
Old Oct 29, 2008 | 10:10 PM
mikewfoster1983's Avatar
are you sure the bulbs are seated correctly. then check the fuse. then the relay
ahawks
Apr 20, 2009 10:44 PM
CASpeyrer
Mar 7, 2007 10:17 PM
blue_sierra
Sep 5, 2006 12:23 AM
akcolby
Apr 20, 2006 12:23 PM
Tylo
Mar 20, 2006 05:21 PM
