Help, frame to body bolt turning
Old Aug 11, 2010 | 04:51 PM
mexpeb's Avatar
Question Help, frame to body bolt turning
hi
installed nurf step bars with 3 bolts each side to body mount bolts. one bolt, (center pass side) just spins, won't go in and won't come out. Anyone know if there is a nut on top or if it threads directly into frame? Also, how to get to the nut if there is one. body trim doesn't seem to come out easily. 2010 1500LT 4wd extended cab
thanks
Ray
Old Aug 11, 2010 | 05:46 PM
chevy112488's Avatar
try to put some pressure on it (pry down while you spin). i have that problem on occasion putting nerf bars on.
Old Aug 11, 2010 | 05:58 PM
mexpeb's Avatar
Thanks, that was my first thought, but there's not enough of the bolt head to get under with a pry bar etc. Funny, but it spins unevenly for about 1/2 turn and then gets a little tight and then turns easily again...sure is strange.
Old Aug 11, 2010 | 07:38 PM
chrisbmo2000's Avatar
Its probably a carriage bolt...you know the ones with the square shank just below the head. Can you just cut it off?
popo
17
Dec 26, 2012 07:58 AM
chucksrt
Dec 22, 2010 02:09 PM
Dangerous
May 24, 2010 09:27 AM
planning_ahead
Feb 18, 2010 09:14 PM
TheMan21
10
Aug 28, 2008 01:12 PM
