Interior LED Lights Help
Old Dec 28, 2011 | 03:57 PM
jarred521's Avatar
Default Interior LED Lights Help
I have an 07 Sierra Classic single cab v6. I want to put LED Light Strips under the dash to act as courtesy lights when you open the door only. I dont want to run them off a switch thats hot at all times. There are currently no courtesy lights under there or anything otherwise i would just wire them up to the existing lights. Any help on what i could safely tie them into?
Old Dec 29, 2011 | 11:15 AM
skeeter5's Avatar
jarred521,
The courtesy lights are connected with a wire from a power source, The other light wire terminal then goes to the door switchs (a wire to each switch), the door switch's other terminal connects to a ground. This lets it work from either door when opened.
dimmuborgir6nik6
21
May 12, 2023 03:58 PM
Billyapb1071
Jan 31, 2013 08:17 PM
KrenayS
Nov 10, 2012 10:01 PM
digger
Jul 28, 2008 05:42 PM
moose
May 3, 2008 11:30 PM
