leveling kit
Old Sep 12, 2008 | 10:05 PM
acsudberry21's Avatar
Default leveling kit
hey guys. I just put new wheels and tires on my 94' z71. I downsized my wheels to a 15" and put 33 1250 15's on. I love them but i have a slight rub on my bumper corners when I flex the suspension a little. I am considering installing a 3" leveling kit and I wanted to know if anyone had any advice about installation. My main focus is to get clearance and secondly to get a slightly more aggressive look. any advice will help.
Old Sep 13, 2008 | 12:13 AM
mitch cobb racing's Avatar
Default RE: leveling kit
will 3' not be too much??
Old Sep 13, 2008 | 12:20 AM
Rhyse62's Avatar
Member
crank the torsion bars, it'll give you 1.5-2 inches but it will make it ride rougher
Old Sep 13, 2008 | 12:32 AM
MajorSilva's Avatar
psh... you don't need to crank the T-bars. A real man just takes a Sawz-all and goes to town.
It's what I did. My 33"s don't rub at all, and I've got a crazy offset wheel too.
Old Sep 13, 2008 | 03:37 PM
how hard is it to crank the torsion bars
Old Sep 14, 2008 | 07:56 PM
Kdhockey89's Avatar
I would not recommend cranking up the torsion bars. This will cause your truck to alignment to be messed up. Also if you do any aggressive driving you will not have as much suspension give. If you have to crank them up just to get tire clearence do as little as possible, but I think the 3 inch lift will do you much better performance wise and it will look better.
Old Sep 15, 2008 | 03:48 PM
04BLKCHEVY's Avatar
To vrank the torsion bars just make sure you have the right size wrench and you are on level ground. Turn the bolt even on both sides. I am goin to do this on my 04HD but only about 1/2 inch to an inch. I would recomend an alignment right after. Also making a clean cut on your bumper isnt a bad idea. Just make sure the line is straight.
Old Sep 16, 2008 | 12:28 AM
well i was not planning on cranking the factory keys. I was going to buy different keys that are supposed to give extra lift. are the new ones going to bebad too or can you keep the factory ride and still crank them. I need to find the cheapest way to get lift without sacraficing ride quality or making new problems. any advice?
Old Sep 16, 2008 | 11:52 AM
jcbst12's Avatar
Honestly I only had about 5/8 of an inch of lift tops on the torsion bars on my 91. Any higher and it would bounce like a basketball over our lovely pot-hole covered, PA roads.
01hd1500
Dec 15, 2007 08:06 PM
garyj
Jun 25, 2007 07:29 PM
Mcfly
Jun 14, 2007 07:00 PM
clix813
Nov 21, 2006 02:30 AM
bro1972
Feb 23, 2006 05:51 PM
