Lifting 2500 and using camper. Will it work?
Old Dec 26, 2007 | 08:39 PM
gtx6pack's Avatar
Default Lifting 2500 and using camper. Will it work?
I have a '07 2500 extended cab that I put my 9 1/2" Lance camper in. I also tow a Jeep at the same time. I love the truck with one exception, the ground clearance and approach angle. I was thinking of a 1 1/2"- 2 1/2" adjustable lift like Ready Lift for the front and blocks in the back. Would I see much difference in my ride and stability with my camper in once I do this? I am worrying about increased swaying.
Old Dec 29, 2007 | 11:54 PM
Chevycowboy's Avatar
Default RE: Lifting 2500 and using camper. Will it work?
Im not too familiar with the 07' model, but i believe you have coil overs up front. There should be coil over risers for your truck that will lift the front up level with the rear. As well it will stiffen your front suspension travel, give you better cornering and reduce sway. drop the axle, throw in 3" rear blocks with longer u bolts, get it aligned, and youve got a lifted hauling towing machine. Hope I helped. Oh and dont qoute me on everything, im going on what i know about the 1 ton, you might have a different setup with the 07' 2500. I did my best. Good luck!
Roger S
Apr 9, 2010 02:07 PM
rd3977
Oct 11, 2008 07:22 PM
Chuck A
Vehicles for Sale
Jun 26, 2008 12:18 PM
tached93gt
Oct 3, 2007 08:37 AM
