Loss of Heating
Old Jun 7, 2006 | 11:18 AM
beacraft's Avatar
Default Loss of Heating
My 2000 Silverado has experienced a loss of heating. Before, if the engine was warm and I cranked the heater and held my hand up to a vent, it could almost singe the hair off. Now, its just slightly warm. I'm fine with it, but the wife and kiddies are gonna be looking for a lil more heat when fall and winter roll back around. Any thoughts on where to start probing?
Thanks
Old Jul 18, 2006 | 12:57 AM
goldfever's Avatar
Default RE: Loss of Heating
hey i totaly understand. the heater coil might be burned out. heater relay might be bad. mine is a 90 and is located onthe pass side firewall behind a plastic cover. not sure about yours. i also changed out my computer which is behind the glovebox but that made my heater a little cooler. my truck wouldnt start for nothing. so i changed a lot of parts then found out the icm was bad. but i put my original computer back in heater works like normal. hope this gives you a couple ideas.
Old Jul 18, 2006 | 08:27 PM
DominicZ71's Avatar
I would check anu-freeze levels.
Heater coil may be out.
Could be a thermostat getting stuck.
start off with the basics first..
Good luck
westtndad
8
Jan 28, 2015 03:06 PM
Bimmerknut
Nov 22, 2008 05:32 AM
Marty
Feb 8, 2008 01:48 PM
tshizzle
Jan 5, 2007 02:46 PM
nightcreeper
Nov 12, 2006 02:28 PM
