Metallic Clunking under truck bed
Old Nov 20, 2011 | 02:47 PM
2KSilverado1500's Avatar
Default Metallic Clunking under truck bed
Hi all,
My 2000 Silverado 1500 Stepside 4.3L has developed a loud metallic clunk under the bed when hitting bumps or going over speed bumps. This wasn't an issue until just recently with the weather going from warm to snow storms/cold almost over night.
I'm assuming the cold weather has caused some contraction of bushings somewhere in back. Any ideas on where I should be looking?
All shocks were replaced on the truck this past summer and upon inspection they still look good. So I don't believe this to be the issue.
Thanks you!
Old Nov 20, 2011 | 03:09 PM
Make sure the shocks are tight, leaf spring bushings aren't broke, leafs aren't cracked, spare tires is tight, gas tank straps secure - you should be able to get under there with a pry bar and find the culprit by moving stuff around. If you have a helper you can have them bounce on the bumper to see if it makes the noise while your under the truck.
Old Nov 21, 2011 | 02:26 PM
bfg112's Avatar
I have my dual exhaust tips mounted directly up against my reciever hitch. They clang sometimes.
MRC Chevy
Mar 31, 2015 05:58 PM
90bronco351
May 18, 2009 09:19 PM
dminnick
Nov 24, 2007 06:45 PM
catchmohl
Sep 1, 2007 04:44 PM
scott70
Dec 6, 2006 09:59 PM
