My 87 Silverado just doesn't have it HELP!
Old Oct 24, 2007 | 05:02 AM
danjorge's Avatar
Default My 87 Silverado just doesn't have it HELP!
I have had my truck in differant shops and the mechanics have spent numerous hours working to try and find out why my truck runs so bad. It doesn't seem to shift properly as I can put the peddle to the floor and I can not spin no tires. It doesn't seem to have the power to clime hills as it semms to shift to late. It starts good and and runs ok but no power when punching it. Also my milage has gotten terrible. The last garage put on an exaust changed full filter and computer chip.
Old Oct 24, 2007 | 07:28 AM
jcbst12's Avatar
Default RE: My 87 Silverado just doesn't have it HELP!
You need to check the fuel pressure. Pump might be just starting to go out. Check the spark plugs and their gap. What did the garage check so far? When was the last time it was tuned up?
Old Oct 24, 2007 | 11:11 AM
gas guzzlin 4x4's Avatar
When the exhaust was changed, did they check or replace the cat's ? Sometimes a clogged converter causes the symptoms that you described.
Old Oct 24, 2007 | 05:15 PM
91CHEVYSILVERADO355's Avatar
im assuming that your truck is a carb'ed truck so it could be your carb the jets might be faulty alot of times if there is water or moisture in the gas tank it can run the jets and cause the lack of power.
fstcarsnguitars
27
Sep 6, 2011 12:36 PM
viper32x
Mar 23, 2010 05:44 AM
Chevyalltheway
Nov 7, 2008 02:14 PM
jafran456
Jun 3, 2008 05:45 PM
Chevyalltheway
Apr 8, 2008 09:15 PM
