need help with my truck asap
i have a 1988 chevy silverado 4x4 and its got a bit of a problem i think its my flasher relay not sure where it is located in my truck and also not sure if its the problem.
the problem when i use my right or left turn signal both of the turn signals go on. my brake lights and headlights and front turn signals work just fine. what could be the problem and can someone tell me how to fix it
sounds like a ground issue also it could be a bad signal switch........the flasher is fine, flashers dont cause that type of problem. are they flashing at the same brightness and at the same time? If not then it is a ground issue. If they are then its probably your signal switch or wiring issue. A few more details would be great
so how do i fix the ground problem and also more details is that the turn signals do work but both of them when i use the left or right also my fuel gauge doesnt want to work. but im more concerned about the turn signals so do i got to take off my tail light cover and reground the wires or what do i need to do
