need specific guidance on my no heat problem
Old Oct 30, 2007 | 10:53 AM
majordad's Avatar
Default need specific guidance on my no heat problem
it's getting colder and I have little heat from the vents. the black box under the glove box is very hot.
can someone guide me to or post a picture of the actuator valve? Better get could someone post a schematic of what controls the fresh air door? I am getting tepid air from the vents after warm up. with the black box hot I am assuming the door is partially open and if closed I would get hotter air into the vent system.
Old Oct 30, 2007 | 12:37 PM
Cracker's Avatar
Default RE: need specific guidance on my no heat problem
This is what it looks like...the actuator.
I haven't been able to find an "in vehicle" photo.
Old Oct 30, 2007 | 12:50 PM
majordad's Avatar
I plan to take the glove box off this weekend to find this thing. is it in or onthe large black box that I can feel as very hot?
Old Oct 30, 2007 | 02:31 PM
Cracker's Avatar
From the info I was able to find it is outside the box. There were hints to the location being behind the center console. I don't really have a direction to point you in for a search. I tried everything from "actuator" to "air blend door actuator, silverado" in a google search without much luck.
Auto Zone or Discount may have a diagram on thier in store computers.
Old Oct 30, 2007 | 05:07 PM
majordad's Avatar
thanks for your help. I'll do just that.
Old Oct 31, 2007 | 02:23 AM
topknotch06's Avatar
heres what you got to do- lay on your back on the floor on the passenger side- in front of where the middle seat or console is at look right under the dash- now you see the pic they posted for you it looks exactly like that- i would check the conection to make sure its not lose- had the same prob the damn connector was lose- good luck
Old Oct 31, 2007 | 05:09 AM
Argon's Avatar
there are 4 of those...left and right temps...mode,and fresh-air....only 1 is fairly accessible
Old Oct 31, 2007 | 06:56 AM
majordad's Avatar
so is this something I may want to punt to the dealer?
Old Oct 31, 2007 | 07:44 AM
Argon's Avatar
you have no heat on BOTH sides?
Old Oct 31, 2007 | 10:53 AM
majordad's Avatar
when the truck has been driven and up to temperature there is a cool-warm feeling to the air coming from all vents. It appears to be equal throughout each vent.
