need specific guidance on my no heat problem
Old Oct 31, 2007 | 01:04 PM
  #11
Argon's Avatar
Default RE: need specific guidance on my no heat problem
if its all vents,I'd look elsewhere...make saure both hoses are hot...make sure its not low of coolant
Old Oct 31, 2007 | 01:33 PM
  #12
majordad's Avatar
I check that last week. both hoses are hot and the coolant reservior is correct.
Old Oct 31, 2007 | 01:52 PM
  #13
Argon's Avatar
ok...I'd say it may be dealer time...it needs to be checked for codes...and pretty much only a gm tech2 scanner will "talk" to the hvac module.
Old Dec 31, 2008 | 06:42 PM
  #14
ft fixer's Avatar
had the same problem found out that my heater core had fallen out of the clip that holds it in and the air was actually blowing over the top of the heater coil
GPEWETT
May 25, 2011 12:46 AM
88rover
Jan 24, 2010 06:26 PM
50msns
Dec 11, 2009 04:53 PM
majordad
Nov 4, 2007 12:37 AM
