no backup lights
Old Jan 28, 2013 | 06:37 PM
digger59's Avatar
Default no backup lights
I have a problem with my 95 chevy as I have no backup lights. the manual says the nutural safty switch on the transmission is what controls them? is this correct? Its an automatic trans,I have no power to the bulbs
Old Jan 28, 2013 | 08:17 PM
NullHead's Avatar
Yup, the manual is correct. The neutral safety switch is exactly what turns on power to the bulbs.
But as long as you are absolutely sure that you have no power (Ground the clamp of your test light and put the needle into the light bulb socket when the truck is in reverse), start with checking your fuse, and work your way up the chain. Do you have power going into the neutral safety switch? Is it coming out and heading out back to the truck? Look at your wiring diagram and see if there are any other connections between the neutral safety switch and the tail light socket.
Old Jan 30, 2013 | 07:40 PM
digger59's Avatar
thanks for the info, as I am working outside i wont be working on this untill the ground gets hard and i don,t get frostbit. I,ll let you know the out come when i get it fixed. thanks again Digger59
williamcarr03
10
Apr 11, 2009 08:10 PM
bradthurman
Jan 8, 2008 03:41 PM
06ado
Sep 24, 2007 11:20 AM
austinmegacab
Mar 18, 2007 05:05 PM
alampaul93309
Apr 22, 2006 04:49 PM
