Not really GM related but close.........
Old Dec 25, 2010 | 07:41 PM
chrisbmo2000's Avatar
Default Not really GM related but close.........
Ok so I have a round 5 post trailer plug on my suburban and trailer.........I am going to put 2 lights in my trailer, each only require 6v each. The question is how do I reduce 12v to 6v so I dont burn up these lights? Basicly I am going to run 12v to the trailer then put in a switch to operate the lights then from the lights I will go to each light. Any ideas or things I should change?
Old Dec 25, 2010 | 09:56 PM
why not just use 12 volt lights?
Old Dec 25, 2010 | 11:05 PM
lol i knew that was gonna be said...............I got these free and im cheap...lol.........just tryin to save money
Old Dec 26, 2010 | 09:28 AM
Can you run them in series to handle the 12 volts?
Old Dec 26, 2010 | 11:29 AM
Thats what I was thinking but wanted some other input and maybe other ideas...I will look into it and see what I can do
Old Dec 27, 2010 | 08:41 AM
SlimJim's Avatar
Probably the cheapest way to do it is to put a resistor in series with the bulb. If you measure the resistance of the bulb and and put a resistor in series with the same resistance, you should drop 1/2 the voltage across the resistor and 1/2 across the bulb. Of course, you have to get a resistor with a high enough wattage to handle the current. Give me the resistance and I can give you the wattage you need. It would be a whole lot cheaper and easier to get a 12v bulb. Good luck.
Old Dec 27, 2010 | 12:08 PM
timber74wolf's Avatar
Are the fixtures set up for 6 Volt or is it just teh bulbs? If it is just the bulbs then put 12 volt bulbs in the fixtures.
Old Dec 27, 2010 | 08:38 PM
The fixtures are set up for 6v. But I did find some LED lights I think Im gonna get instead. But I still may wanna go this route.
Old Jan 4, 2011 | 05:57 AM
jvp's Avatar
jvp
Member
Before you think cheap think dependable, nothing is worse than to be on the road
and start blowing fuses and repairing wiring problems with trailers and your tow vehicle.
Can the 6 volt idea and just use 12 volts and save yourself a lot of grief latter.
vp
Old Jan 4, 2011 | 03:08 PM
Go with LEDs. Much brighter and efficient.
Wiked
8
Aug 5, 2011 05:36 PM
killercripple
Mar 1, 2011 03:54 PM
soundhd
Jan 12, 2009 10:21 AM
72charger
Jan 13, 2008 01:55 PM
RobF1970
10
Jul 30, 2007 09:23 PM
