obd1 obd2 etc
Old Oct 3, 2007 | 07:35 AM
  #11
Argon's Avatar
Default RE: obd1 obd2 etc
it does everything faster,but its mainlyfor faster communications between modules.
ob2 began "slowing down' around 2000....too many modules talking to each other...one would "brain freeze"...(logic lock is the term)
it was great when we had a pcm,bcm,and airbag module...but when the radio,cluster,keyless entry,dvd,etc all became modules,it was too slow.(they all talked to each other on 1 wire)
engineers finally decided it was not necessary for the dvd player to talk to the brake module,so they split it up with LAN
LAN is a very high speed network with 2 speeds...super high and high.the ecm,bcm,anti-lock,and airbags are on the super high side.(very close to real time)....all others on the other side.(an 08 suburban can have about 22 modules)
And it all has priorities programmed in.....The wheel speed sensors report to the brake module,which ships it to the pcm and cluster....You press the window switch for it to fgo down,the driver door module sends the command to the bcm...in the middle of all this,you hit something...so LAN says screw the window and speed signal..SET OFF THE AIRBAG!
Old Oct 3, 2007 | 07:49 AM
  #12
jcbst12's Avatar
Ok makes sense. So each module has a priority and connected to the ECU based on that priority. Like you said with anti-lock brakes, they use the "interstate" connection and the radio would use a separate "two-lane road". Ok got it. And when it came time to add another 22 modules a few years down the road (like the electronic valvetrain idea) they can always add another line to the system.
Worf
GM How-To's and Tutorials
8
Jun 4, 2013 10:59 PM
Worf
Dodge/ Ram How-To's and Tutorials
Jun 30, 2012 04:05 AM
Worf
Ford How-To's and Tutorials
Apr 11, 2010 04:56 AM
Mcfly
22
Aug 26, 2007 04:50 PM
ace
Aug 10, 2005 06:45 PM
