Oxygen sensor DTC P0036 will not go away.
Old Apr 24, 2012 | 02:26 PM
deepstuff's Avatar
Question Oxygen sensor DTC P0036 will not go away.
Had DTC P0036, Replaced drivers side post Cat sensor and reset DTC. P0036 keeps coming back.
’07 new body style 6.0L Vmax
Old Apr 25, 2012 | 05:22 AM
acnas's Avatar
Disconnect o2 connector an check the truck side pink wire terminal D for 12 volts key on with a test light to ground. If not check underhood fuse o2 b snsr. Did you use GM 02 sensor? How many miles on it?
Old Apr 25, 2012 | 07:01 AM
deepstuff's Avatar
Question
Used a DENSO sensor as a replacement. Original had 84,000 KM
Denso has about 100KM now but P0036 came on right away after being reset.
tonygr
Jun 26, 2011 09:04 AM
7060
Oct 10, 2009 05:22 PM
chertman47
Aug 9, 2009 07:57 PM
edparss
10
Jul 9, 2009 07:55 AM
sueb
Aug 14, 2006 07:07 PM
