P0300 - Cyl 4 - When under higher load
Old Jan 17, 2024 | 11:09 PM
Rex Smith's Avatar
Default P0300 - Cyl 4 - When under higher load
2001 Silverado 1500 - 4.3L 380k miles
1.5 Years ago - I finally decided to put the truck in a local shop to chase the CEL that illuminated LITERALLY a day before I was going to take it in for annual state inspection.
Several things were addressed and fixed by the shop (intake resonator box had air leaks causing lean conditions, fuel pump & FPR changed, evap canister, injectors changed & upgraded to the newer style)... I myself changed plugs, wires, distributor cap, ignition coil, water pump, and fan clutch (All were suspect - and way past time to have replaced them...
A P0300 still is a ghost that occasionally appears, though. I've narrowed it down to happening generally when the engine is under higher load. (i.e. driving up a slight hill if it's a mile or longer - the check engine light will flash, then turn off once the load has been reduced on flatter (or downhill) terrain) I picked up a scanner to read live data for the misfires, and it looks like Cyl 4 is the main culprit. (see screenshot - and I did reset the numbers while on my trip)
With cyl3 & 5 also having some misfires along with 4 - but not nearly as bad. When this happens - I feel NO change in the engine performance. No shake or roughness at all that I've noticed.
I'll do the obvious quick checks this weekend to check plug/wire and distributor cap (since firing order is 1,6,5,4,3,2 - with 4 having the other offenders (3 & 5) on either side of it's firing order... but was curious if anyone had other ideas for me to check.... Could it be PCM, if it's not the obvious spark plug/ dist. cap ?
Dec 29 2023 - Between Dallas & Lubbock
Jan 2 2024 - Between Lubbock & Dallas
Old Mar 24, 2026 | 09:09 AM
NioMarvin83's Avatar
P0300 with counts piling up on cyl 4 under load is often ignition breakdown on the 8.1. Start with the basics: pull the #4 plug (check gap/insulator), and inspect the plug wire for heat damage or arcing?these wires love to cook next to the manifold; swap the coil and wire from #4 to another cylinder and see if the miss follows. If ignition checks out, do an injector balance or swap #4 injector, and verify fuel pressure under load with a gauge so it?s not leaning out. If your check engine light also triggered Reduced Power, clean the throttle body and check for TAC/APP codes and loose connectors at the throttle body and pedal.
darkyellowsky
22
Mar 17, 2022 04:27 PM
denwayanderson
Aug 3, 2010 11:26 PM
hazzard01dukes
Jan 30, 2009 11:41 PM
slider
Oct 24, 2007 04:53 AM
nakins
Jun 5, 2007 06:15 AM
