Parking brake adjustment?
Old Nov 16, 2009 | 03:00 PM
woodyman's Avatar
Default Parking brake adjustment?
2002 1500HD -- 83K mi. Is there an adjustment on the parking brake linkage? If yes, where is it located? My pedal really goes low to the floor when I use it. Thanks
Old Nov 17, 2009 | 11:27 AM
SlimJim's Avatar
I have found if your rear brakes are in adjustment, the parking brake is good. I assume you have rear drum brakes. I have never had luck on depending on the automatic adjusters. I usually adjust the rear brakes manually and the parking brake comes back to where it supposed to be. Good luck.
Oops....I just noticed you have a HD and probably have disc brakes. I'm not sure on yours but on others that I've looked at you had to get into the cable length adjustment.
Old Nov 18, 2009 | 03:48 PM
woodyman's Avatar
Default Tthanks Slim
Yes they are disc brakes. I just now finished putting new rotors and pads on the fronts. Guess I'll need to slide under there and take a look. I guess if I start at the rear wheel and follow the linkage to the front, if there's an adjustment there, I'll find it. I'm just getting too old to be crawling under it. Thought someone might give me a place to look first. Thanks again, W.
Old Nov 18, 2009 | 08:59 PM
Just follow the cable back about 1/2 way and you will see where it Y's into 2 cables. There is a threaded section and a nut there that can be adusted. If it is adjusted all the way out you can add a spacer in there to get a little more out of your cable.
Old Nov 19, 2009 | 12:39 PM
glterpening's Avatar
Woodyman, Are your rear pads OK? Seems like if the auto adjust mechanism was not working right and the pads were low, it would cause the same symptom.
Gerald
Old Nov 19, 2009 | 10:10 PM
The e-brake actually works off of rear shoes inside of the rotor. So you have both disk and drum brakes back there. I had the same issue with my truck and replaced the rear shoes and the pedal remained the same - LOW. I tightened the adjuster at the "Y" in the cable and it got a little better, but was still not as high as I would like. So I installed the spacer and it was perfect. These cables will actually stretch with age and use and that is what causes the low peddle.
Old Nov 20, 2009 | 09:03 AM
Thanks, Mr_Shamrock. Very good info!
Old Nov 26, 2009 | 08:05 AM
GyprobE09's Avatar
The parking brake on my XC 90 requires considerable force to apply and only travels a few clicks. How can I loosen it off a little. I can find no adjustment underneath the car. Have removed the cover around the pedal to expose the crank mechanism but still cant figure out how to adjust. This is a RHD model.
Old Aug 23, 2010 | 10:14 AM
jmilleraf426's Avatar
hey guys just a quick question, where did you get the spacer at and how much did it cost?
Old Aug 23, 2010 | 11:58 AM
I had one that worked in my collection of nuts and bolts. It does not have to be a specific spacer and you could even just stack some washers. I would say that you should check your e-brake shoes and the drum first to make sure everything is in spec. I did with mine and the last thing I did was shim the adjuster after everything else was either replaced or checked to be within spec. You are basically just taking away some of the slack out of the cable with the spacer. Once you get down there and are looking at it you will see what I mean.
Mr_Shamrock
10
May 1, 2021 09:28 PM
fever
Oct 8, 2009 02:44 PM
Mr_Shamrock
Jul 23, 2009 07:49 PM
MrLM7
Apr 19, 2007 06:32 AM
99z71325ci
Jan 9, 2007 10:09 PM
