Power Seat problem
Old Jul 27, 2007 | 11:06 AM
rgbraun1's Avatar
Default Power Seat problem
1999 Silverado. Power seat slides about 1/4 inch back and forth. Can make this happen by hand or when I stop the truck I the seat slides forward and then when I leave the stop sign/stop light it slides back. Looked around under the seat, all bolts tight. Seat just slides on the rails. What's going on?
Old Jul 27, 2007 | 06:28 PM
smoke20's Avatar
Default RE: Power Seat problem
Have you lookat at the teeth on the motor?
Old Jul 27, 2007 | 08:16 PM
rgbraun1's Avatar
I was thinking the same thing. Do you know if they are visible when I remove the seat?
Old Jul 29, 2007 | 06:07 AM
Argon's Avatar
Man..what a problem...the seat needs to be flipped over to find out wtf...its easy to remove...but takes some inverted torx sockets
Old Aug 6, 2007 | 04:03 PM
airmech_1's Avatar
boy this can get bad. I got the sockets took the seat out and took the scew drives out and found out that something on the square drive got ate up cause i picked pieces out. So I called dealer and they said can only order the whole bottom part of the seat for $300 or so[:@]. anybody had this same problem? I think there will be more.
Old Aug 6, 2007 | 07:09 PM
Argon's Avatar
I told ya...they suck...look for a used base maybe...but its a nitemare to install as well,so I'd hate to do it twice
Old Mar 25, 2011 | 10:45 PM
6.0gmt800's Avatar
I had this same exact problem on my 2000 gmc sierra. There is however, finally, a guy on ebay selling kits to fix them for $15, I put one in about a week ago that took all the slack out. Much better than the $1,100 the dealer quoted me.
He lists them as: GM/Chevy Power Seat Unwanted Movement/Play Repair Kit
Gotechslack
Feb 3, 2010 04:22 PM
Ricks66
Sep 22, 2009 08:06 PM
ralphb
May 28, 2009 05:56 PM
ralphb
May 27, 2009 12:45 PM
Eddie
Dec 1, 2007 12:55 AM
