Push button 4WD/Plow
Old Jul 16, 2007 | 11:36 AM
wannarex's Avatar
Default Push button 4WD/Plow
My 2003 1500HD has the electric, push button 4WD system. Which I know nothing about. With this system can I install a plow on the truck? I should probably check at a dealership, but would like your knowledge as well.
We can get some serious storms here. Up to a foot is not uncommon. Last April we got a storm that dumped 20-24 inches and the temps were high 20's and low to mid 30. It even rained in the middle, so the snow was quiteheavy.
Old Jul 17, 2007 | 05:56 PM
smoke20's Avatar
Default RE: Push button 4WD/Plow
No idea, we don't get snow here. but we make up for it with 105+ temps alot like today with a ton of humidity just for fun.
Old Jul 19, 2007 | 08:53 PM
gm trucker's Avatar
I am assuming you are talking about the Autotrac feature, ie., auto 4x4 mode. You can definately plow with this set up, probably 80% of the trucks up here in Canada have the push button. Now here's where you gotta be careful... DO NOT use the auto 4x4 mode for plowing, only use 4 hi or 4 low. The auto feature has clutches which engauge/ disengauge and will prematurely wear out. Hope this helps you.
Old Jul 21, 2007 | 08:29 AM
wannarex's Avatar
ORIGINAL: gm trucker
Thanks for the info. I definitely do not plan on using the AUTO 4x4 feature for plowing. I probably won't even use that at all. I think I would want it in or out of 4WD.
Sorry to be so old fashioned. It took awhile to convince me automatic front hubs are OK. I'm a little suspicious of electric engagements, systems.
Old Jul 21, 2007 | 11:13 AM
Chevyvehc's Avatar
haha that reminds me of just the other day I stopped in at a dealership in Bastrop, they had a 1983 K30 4x4 454. It was all decked out with a 12" lift and 36inch mud tires. It has been raining a LOT and I wanted to test drive it in the mud. Me and my aunt got in it and I was trying to put it into 4x4...But forgot to unlock the front hubs >.< Needless to say...no 4x4 action that day =(
Toma21
Mar 11, 2012 03:13 PM
sqdqo
Apr 1, 2008 08:44 AM
sleepybarge
Oct 3, 2007 06:27 PM
LightningStrong
Aug 20, 2007 04:41 AM
GEARHEADRT
Jan 4, 2007 10:30 PM
