a question ya'll are tired of hearin im sure. (truck dies)
ok my 1990 sierra 2wd with a 4.3 v6 will start and as long as im pumpin the gas. it'll idle and then slow down till it dies in about 10 seconds. it also billows whit smoke if that helps. just got it and the guy said he replace the fuel filter. i put a new pump relay to get it to do this much. i got the bed of the truck off cause im also cleanin the rust off the frame. any ideas? ive replaced the air filter. i searched on here but either the question others had wasnt exactly like mine or the guy never replied back what he did. it has that throttle injection with 2 injectors. thanks.
Yeah that sounds like its starving for fuel. When motors run lean you will see white smoke. Or if its burning oil it will also throw white smoke. But you could smell the burnt oil. Need to put a fuel pressure guage on there. Could be the pump, or the fuel pressure regulator. But the fuel pressure guage will give you a better idea as to what it could be.
someone told me to check the egr. its ok. im tryin the free stuff first lol. theres a flap in the intake that is hard to move down im gonna try to lube it and hold it down even and see if that works. but i can get a gauge tuesday from work.
scubiesteve
Sep 25, 2010 12:31 PM
cybredon
Nov 30, 2006 08:13 AM
