A quick question????
Old Jun 25, 2008 | 06:59 PM
  #11
EarnhardtZ71's Avatar
Default RE: A quick question????
Yeah I got an idea of what to do now. The engine needs to be cool to do this right? I ask this because last night when I put on my tbs, I unhooked the coolant line on the driver's side and coolant shot out of the hoses.
Old Jun 25, 2008 | 07:49 PM
  #12
rxsteven's Avatar
I would wait for it to cool for sure!!
Old Jun 25, 2008 | 08:43 PM
  #13
jcormier89's Avatar
so exactly how is it done?
Old Jun 26, 2008 | 12:04 AM
  #14
rxsteven's Avatar
Well on the left side of the TB (throttle body) is a kind of small black hose that comes from the left side of the radiator. On the other side of the TB is a hose that is the same diameter but much shorter in length. Remove the shorter hose completely. Take the longer hose off the TB and connect it to were the shorter hose went. You will have to re rout the hose a little but it should reach. You can get vacuum line caps at a parts store to cap off the TB. Now if you have electric fans the longer hose might be different but I dont really think they are.
Old Jun 26, 2008 | 06:09 AM
  #15
Thanks man I think I can handle that. I don't have electric fans. I should be able to do this without much problem.
Old Jun 26, 2008 | 07:23 AM
  #16
bad2006z71's Avatar
rxsteven, did you notice any better throttle response or mpg's from this? or was it mariginal and barely noticeable?
have a good one.
Old Jun 26, 2008 | 07:38 AM
  #17
jcbst12's Avatar
With the coolant bypass, you don't really notice a difference in the summer, but in the winter my truck was a little more touchy on the pedal on colder days. Not a huge difference but it was there.
Old Jun 26, 2008 | 08:28 AM
  #18
Every little bit helps right?
Old Jun 26, 2008 | 10:59 AM
  #19
rxsteven's Avatar
No you wont notice any thing but the clder the air the better. I think if you had a intake temp. gage you would see a difference.
Old Jun 26, 2008 | 11:41 AM
  #20
jcbst12's Avatar
Yeaqh it could have been touchier just because of the cold air alone, but either way i don't need a heated TB anytime of the year.
