Rear diff swap
Old Mar 27, 2012 | 11:28 PM
fzee's Avatar
Cool Rear diff swap
I have a 1998 C 1500 2 WD that I would like to swap out the rear diff to a C 2500 so that I can haul my bike in the back as well as pull my bumper pull trailer. the tongue weight of the trailer is between 5 and 6 Hundred lbs. My bike weighs in at around 800 lbs. Just looking to create a little extra ability to haul both safely. I am using an equalizer hitch and I have air bags as well but I am concerned that the axles and bearings may be to close to their limits.
I won't mind changing to six lug from five but I'm not sure if six will do or if I need to go to eight lug wheels and axles. Can i just change axles??
Any suggestions or recomendations? I don't want to haul the world!! Just want to add a little room for safety!!
Thanks!
Old Mar 28, 2012 | 02:28 PM
TMW's Avatar
TMW
You can check the sticker on the drivers side door frame and it should tell you what the load capacity is. I think a 1500 is about 2000 lbs. So what your carrying is OK, 800+600=1400lbs. I'd be a little concerned with the tongue weight on the bumper. 5-6 hundred lbs is close to the maximum I think. You may be better off putting a trailer hitch on it.
Old Mar 29, 2012 | 12:30 AM
fzee's Avatar
Thanks! I did not mention that I do have a class 3 reciever hitch on it. "Bumper pull" is just a phrase that the RV world uses! I will Look at my sticker in the morning though!! Thanks again!
Shuckles
Nov 22, 2011 04:37 PM
2500_DW
31
Dec 10, 2007 06:02 AM
Rbizz
Jul 11, 2007 03:00 PM
shaved88
Apr 3, 2007 11:17 PM
vetteboy86
Feb 11, 2007 05:25 AM
