Rear drum to disc brake mods?
Old Jun 27, 2009 | 03:07 PM
Denali93z71's Avatar
Default Rear drum to disc brake mods?
Has anyone out there swapped late model rear disc brakes on their k1500 truck?
Old Jun 27, 2009 | 03:12 PM
RUFFNECK4LYFE's Avatar
Do it. Its a nice upgrade. You will get a little more braking power.
Old Jun 27, 2009 | 03:28 PM
What donor vehicle is required for the swap and will I need a new master cylinder? BTW my truck is an extended cab z71 with single piston disc up front and drums out back. Also, I noticed a late model tahoe at the junkyard.
Old Jun 27, 2009 | 03:52 PM
Well the tahoe uses rear disc's but they also use coil springs so you would have to do a little fabrication to make that work. Try to find a rear end off another truck that will just bolt up and go. Like a 99-06 HD. Try to match the driveline too. Like the driveshaft and transmission.
antjenn
Feb 26, 2009 07:24 PM
mario29
Mar 28, 2008 08:49 AM
sanderevo
Jan 13, 2007 02:46 PM
Sinjin1952
Nov 5, 2006 03:51 PM
