Rear End Maintaince
Old Mar 7, 2007 | 02:19 AM
chevy1224's Avatar
Default Rear End Maintaince
How often should you change the oil in your rearend??? Also how hard is this, and any other nice details would be appriciated. Thx.
Old Mar 7, 2007 | 08:01 AM
Argon's Avatar
Default RE: Rear End Maintaince
I assume we're talking newer truck?..(gmt800?)
100k/...SOME trucks have a drain plug at the bottom of the pumpkin,making this simple...others,the cover has to come off.
Many quickie-lube places "suck" the oil out.
Here's the kicker..The rear end oil in these trucks is synthetic...The gm stuff is almost $25 a quart....it takes 3 or 4,depending on the rear end size....I'm sure there are cheaper oils,but DON'T USE the old 90W gear oil...it has to meet the requirements.
Old Mar 7, 2007 | 09:23 PM
chevy1224's Avatar
yea, its an 02 truck... sry, but i guess ill hold off on that one, seeing as i dont want to drop $100 for oil, and i only have about 68k miles...
Old Mar 7, 2007 | 11:49 PM
popo's Avatar
I'm sorry I just found the title of this post hillarious!!!!!lol
Old Mar 8, 2007 | 01:41 AM
chevy1224's Avatar
lol, yea... didnt realize when i wrote it...
Old Mar 8, 2007 | 05:48 PM
BigTexasChevy's Avatar
just be glad your rearend made it to 68k....mine made it to 3,800 miles and then took a **** on me!!lmao im the lucky guy who has the truck that falls under the .4% major defect category!! WHOOHOO!
Old Mar 12, 2007 | 09:54 PM
chevy1224's Avatar
well your problem was you let your rearend get all clogged up with gunk, and then it just exploded because of the pressure... Im a doctor/mechanic i should know jkjk
Old Mar 12, 2007 | 10:35 PM
gm trucker's Avatar
Check to see if you have the Eaton (G80) locking rear diff., there is a break in peroid for it. So if it has G80 I would change it right away because it probably has the original oil in it. It also requires a seperateadditive available from your dealer.
If it's the regular diff., I think it's like every six years or 60k whichever comes first.
Old Mar 13, 2007 | 08:00 AM
Argon's Avatar
The additive is for older g80's...(98,etc)...the gnt800's all take the synthetic oil....changed at 100k
trev0006
Feb 13, 2013 09:01 AM
ABSPUD
Jul 18, 2009 03:59 AM
dogpile
Nov 16, 2006 05:13 AM
gman26
Sep 13, 2005 01:19 AM
fourwheeler88
Apr 6, 2005 02:54 PM
