Rear end swap
Old Jan 30, 2008 | 08:15 PM
Birdable67's Avatar
Default Rear end swap
My son has just destroyed his 3rd rear end in his 89 Silverado 4X4. He is running a 350 thats built a little much (400 hp at least), racing prepped 700R (one thats finally holding up). Any of you know of a Detriot Locker unit that was supposedly stock in an 86 Silverado? I found one in a local swap magazine for a great price but I have questions.
Should I have any issues swapping this drum to drum? Driveshaft length would be the same? Are they stronger units than the stock ones he keeps wiping out?
Any info you folks can offer will be greatly appreciated - surely I am forgetting something here.....
Old Jan 31, 2008 | 09:49 AM
04BLKCHEVY's Avatar
Default RE: Rear end swap
I really don't know much of a locker that came stock in 86. What I do know is that the locker doesnt affect anything. As long as it matches up with the gears inside. What size rear diff is it now? The trucks in the 80's made it easy were you can swap any rear end(bolt-on). I don't know if it changed in the late 80's. Sounds like he needs a 14 bolt full floater.They can be found in the chevy 1 ton trucks and thelate modelHD's.
Old Jan 31, 2008 | 03:30 PM
stopspazinout's Avatar
itll be hard to get a 86 to bolt up right to an 89. if you keep blowing out the stock rear end you probably have a 10 bolt. you should either step up to a Gm 14 bolt or a ford 9 in.
Old Nov 2, 2009 | 11:22 PM
lc61885's Avatar
All i got to say is make sure the gears are matching front and rear.
trev0006
Feb 13, 2013 09:01 AM
ABSPUD
Jul 18, 2009 03:59 AM
89cheyenne
May 25, 2009 01:24 AM
repotime
Sep 26, 2008 11:48 AM
gunmetalsilvy
17
Dec 13, 2007 08:21 AM
