2 Attachment(s)
Didnt have much to do today and it was pretty nice but i got the cab off the 86 frame and moved my 14bolt in the garage and pulled the drums off. The plan for it is to keep the 4.10 gears get a locker, and the drums are not in real bad shape so ill prob turn them down on a brake lathe make sure there true and just throw some new pads and hardware on. It already has brand new wheel cylinders from before i bought it.
Id like to do disk brakes but i figure if i can get away with something that still works good and is pretty cheap i will do that if i feel the need for disks later on i can always upgrade. Attachment 2000 Attachment 2001 |
Drums work fine as long as they're adjusted and working properly.
Originally Posted by NullHead
(Post 74457)
3 Attachment(s)
Got my black truck mostly torn apart, im going to have my buddy come get it today or tomorrow to go to scrap hes buying this and he bought a parts cavalier i had and hes giving me a good deal on a D60 axle.
But as soon as i pull the heater box and steering box off im going to have him come get it then i can go pick up my dana 60 Attachment 1995 Attachment 1996 Attachment 1997 |
Rest in pieces 84. The rest of it rolled away on a buddies flatbed today. Im going sometime this week to look at dana 60s he said he has a dodge one with 4.10s he would sell me but also has a GM one which is the one i will probably get because i was reading about the dodge d60s and they need some modifications to fit properly so i would rather choose bolt on over changing things.
I do have one question though my rear has 4.11s in it now and im debating on keeping them or going to a 4.56. The truck will not be driven on the road very much, just occasionally but when it is i would still like to be able to do 70 or so down the highway. I will be running an sm465 backed by an np205 so what are your guys opinions, i would like to sort that out before i get lockers because the 4.11 and down and the 4.56 and up lockers are not interchangeable. Anyway i will also probably be ordering my rear shackles and front spring mounts from DIY4X soon. |
Ok well tonight i picked up my dana 60, tomorrow im going to clean it up some and try to figure out what gears are in it ill post some pics then. But the next couple weeks is probably going to be pretty slow, im going to order my DIY4X parts after next weekend because we are going to Motorama in Harrisburg, Then i need to find the lift springs i want to use.
2 Attachment(s)
I really really hate frozen mud. I should have cleaned it last night before it froze hopefully it warms up some so i can clean it my pressure-washer barley even touches it.
Attachment 1993 Attachment 1994 |
2 Attachment(s)
Well today i sandblasted the trans and t-case. It didnt really turn out that great the cheapo craftsman sandblaster just didnt have enough guts to get all the stuff off, i think if i would have sprayed some degreaser on it the last couple days and washed it first it would have worked but its done now.
And i cleaned up the silver overspray that was everywhere after these pics so black is where it should be and so is the silver. Attachment 1991 Attachment 1992 |
wow awesome that looks pretty good! Keep up the good work and pictures
4 Attachment(s)
It warmed up a little bit the last couple days so i was able to clean the D60.
Attachment 1987 Attachment 1988 When i was pulling the diff cover off i cleaned the ratio tag and saw that it should have 4.10s in it Attachment 1989 I continued to pull the diff cover off and what i found wasn't what i was hoping for, some nasty looking oil and a good bit of water and ice. I come to find out that the pinion seal is leaking which is still not a real big deal. Attachment 1990 So now this axle is going to get torn down and cleaned really good both inside and out along with a nice sandblast and paint, for now im keeping the 4.10s in the front rear and not going to lock it, If i like the ratio ill put lockers front and rear if not ill change gears then do lockers, but plans for the D60 are all new brakes, clean, paint, Crossover steering and replace necessary things. |
