Slight problem after new wires
hey, i'm new to the web page. i have a 2006 crew cab silverado with a 5.3. i recently changed the stock spark plugs and wires out with E3 spark plugs in and MSD 8.5 mm super conductor wires. i did the plugs first and a week later did the wires. now after the truck is warmed up it'll shutter a little bit and the rpm's will drop just slightly. it'll only do this if i'm not moving. once i get going it runs great... a lot better than before i changed everything out. any ideas on what could be going on?
other things i have on the truck are K&N CAI, Jet TBS, and i descreen the MAF sensor.
OK well that rules that out. Bad batch of fuel or has this been going on for a while. Are you running a supercharger or some other sort of forced induction? Just wondering why you descreened the MAF with a N/A 5.3l.
I plan on filling up tomorrow so that could answer the bad batch of fuel question.
What do you mean by a N/A 5.3l. might i have screwed something up by descreening it?
I'm not running a supercharger or any forced induction either.
See what happens with the new batch of fuel. I usually stick with AC Delco plugs myself so I'm not going to pass judgement on the E3's.
N/A= Normally Aspirated. The MAF from the factory will flow more than any of us will ever get out of these engines. I personally wouldn't descreen one, guys are running close to 500 hp with factory MAF's. Some folks think it is the miracle cure for cheap hp.
I am about to start installing a magnacharger on my 5.3 and I wouldn't consider descreening. Good luck and I hope it's just bad gas.
