starters getting hot electrically have gone through 6 starters in six months
Old Mar 21, 2010 | 11:18 AM
mudman_1's Avatar
Default starters getting hot electrically have gone through 6 starters in six months
was hoping someone had an idea of what might be the problem it is a chevy k-1500 i just dropped a new motor in it right from the crate and it is doing the same thing old motor was doing
Old Mar 23, 2010 | 09:02 AM
Magoo's Avatar
Member
Default Headers ??
Do you have aftermarket headers? -- Heat from headers can be harmful to a starter.
Old May 24, 2010 | 06:07 AM
misterk's Avatar
do you have it shimed right?
Old May 24, 2010 | 12:13 PM
chrisbmo2000's Avatar
CHECK YOUR GROUND!!!!!!!!!!!!..........and all other connections for corrosion and make sure they are tight.............headers and shimming will cause this also
Old Sep 1, 2010 | 09:58 PM
CHECKSIGHT's Avatar
there is a short within the wireing harness. Break out a schematic and start tracing! Most possible cause of this problem. Stray voltage continuing to the starter after bendix release. Could also be the the key switch! Shoot your key hole with electrical cleaner and then drench with silicone spray to rule it out first. If the problem goes away then it's the switch.
Old Sep 1, 2010 | 10:04 PM
CHECKSIGHT's Avatar
highly suspect your key switch! Shoot electrical cleaner into the switch and then drench with silicone spray. See if that stops the short or stray voltage to starter when the bendix returns to détente position after release of key! Very likely cause my friend and i hope this helps.
danadoll
Oct 19, 2010 03:39 PM
richison
Jul 6, 2009 09:27 PM
WALT258
Jan 21, 2009 07:07 PM
ljhelmick
Dec 24, 2008 08:38 AM
ljhelmick
Dec 24, 2008 08:24 AM
