Stripped out Transmission pan bolt
Old Jun 13, 2011 | 07:18 AM
brohnson's Avatar
Default Stripped out Transmission pan bolt
I've bought a used 1999 GMC Sierra 1500 5.3L and I wanted to service the tranny but the bolt is stripped out beyond any help like a smaller socket, etc. Someone told me I can weld a new nut onto the stripped out one, is this safe to do why its still all hooked up to the tranny or will I burn up the fluid or anything in the tranny. I think all I'd have to do is tac weld the nut on so I cant see doing anything wrong to the tranny but thought I better ask first.
Thanks, Tim
Old Jun 13, 2011 | 07:43 AM
Can you grab it with some vice grips and then just replace the bolt?
Old Jun 13, 2011 | 09:00 AM
I understand your concern... The tranni oil pan bolt is steel and the tranni housing is a lighter, more mild metal. But your friends idea is doable. Use a mig welder, and do it quickly. Spot weld the new bolt to the stripped bolt quickly, then cool it rite away.
During this heating process, the stripped bolt will probably come lose too.
Old Jun 13, 2011 | 10:43 AM
brohnson's Avatar
I cant grab it with anything its stripped out like a circle, I did some research and found that using a dremel, cut a slot into the side of it and use a chisel or screwdriver and try and hammer it loose. I think I'll try that first, if not than I'm tac welding a nut onto it.
Old Jun 13, 2011 | 05:38 PM
cubpak89's Avatar
or you can use an extractor set
Old Jun 13, 2011 | 10:18 PM
Keep us updated on you progress
Old Jun 14, 2011 | 10:14 AM
tasutt2009's Avatar
old mechanics trick... die grind a slot in what use to be the head of the bolt and use a slotted (common) screw driver. add the use of a cresent wrench if needed for better torque.
chucksrt
Dec 22, 2010 02:09 PM
Worf
GM How-To's and Tutorials
Apr 14, 2010 02:31 AM
Worf
Dodge/ Ram How-To's and Tutorials
Apr 14, 2010 02:29 AM
Worf
Ford How-To's and Tutorials
Apr 14, 2010 01:14 AM
mrglass
Oct 22, 2007 04:34 PM
